Hi
I want to buy a Numark DMC 2 controller. My question is are there drivers for it for Windows 7 64Bit?
I can't seem to find any anywhere no matter how much "Googling" I do.
Do these drivers exist?
Thanks
Thanks
geposted Tue 08 Jun 10 @ 6:14 pm
It's a HID device .. it doesn't require drivers as it doesn't have a soundcard.
But, since it is a NUMARK product .. you should get their word on it first. But, you should not need drivers.
geposted Tue 08 Jun 10 @ 6:24 pm
I own the DMC2, it is an awesome controller, and does not require drivers. However you will probably want to pick up a USB mixer (I use the C3USB mixer with it) to use as a sound card since it does not have one built in.
Michael
Michael
geposted Wed 09 Jun 10 @ 7:51 pm
Awesome! I currently use the DAC2 with the Maya44 USB soundcard. So I'd be basiclly switching to the DMC2.
Does it work well on Windows 7 64 bit?
geposted Thu 10 Jun 10 @ 4:44 pm
