Just checking if the skin resolution affect the performance of the computer??? the highest resolution on laptop is 1366 x 768 not much to choose for this resolution.. any suggestion.??
geposted Tue 08 Jun 10 @ 9:26 pm
The higher res, the more ram is used.. but not that much ;) I dont think you need to worry about it :)
Run a resolution that matches your screen or fills it as much as you can, and i dont think you'll experience any problems
geposted Wed 09 Jun 10 @ 3:22 am
I'll try. What about when you run your pc on 32bits 16bits. The reason I ask is because I'm using just video and I just e
want to free as much ram as possible
geposted Thu 10 Jun 10 @ 2:44 am
It's better to run a skin fitted to your resolution.
I know there are a only a few.. check here
https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=1366&search=
but you can use Skin Resizer to resize your favorite skin.
geposted Thu 10 Jun 10 @ 7:56 pm
