Topic: WOULD THESE SUBS BE ANY GOOD??
Nady PSW-152 Dual 15-Inch Subwoofer Features:
* Dual 15" subwoofer speaker
* 800W peak power rating - 400W RMS
* 4 ohms cabinet
* Durable black carpet covering
* Heavy duty plastic protective corners
* Integrated recessed carrying handles for easy handling
* Binding post (banana jack) and two 1/4" (6.3 mm) jack inputs
Nady PSW-152 Dual 15-Inch Subwoofer Specifications:
* 20-400Hz frequency response
* Max SPL 107db at 1M
* Dual mounting pole adapters
* 39.5" x 22" x 20.2"
* 107 lbs.
geposted Wed 09 Jun 10 @ 2:31 am
Compared too?
Do you have Nady tops?
Quick (simple) rule of thumb is your subs should be a minimum of TWICE the power handling of your tops.. (with an amplifier thats matched at the peak rating)
IE: I can take a single Peavey SP118, and match it with an amp bridged into 2400 watts...
making the Nady's sound like a home sub.. but that would be silly if my tops were only 200 watts rms ;-)
Good or bad, really depends on what you want to use them for..
Usable low end of those dual 15's are not actually to bad, and would probably be fine for mid too small size parties/rooms..
Are you thinking of purchasing one or two?
I ask because if you go with just one, AND you want to run your amp bridged, then you need a 2 ohm capable amp.
