geposted Tue 03 Aug 10 @ 9:21 am
haz0rd wrote :
Vista gave me nothing but issues. even discovering the device gave me problems
W7 Works well but XP was the best in my experience.
Paul Cole wrote :
Thanks man,
I think your right! Got to go with Windows 7.
+1
Just upgraded my laptop with a ssd drive and installed W7 aswell but Xp Pro is the best alternative for my latency..
geposted Tue 03 Aug 10 @ 9:23 am
Hi guys I have this same problem with crackling. I am running vista on lappy 4g dual core.
It comes and goes I have changed mixers no joy yet.
Is running XP or win 7 a cure, if so which is better.
Has anyone got any other ideas to stop it. I have vdj 7, using denon 1200 cd decks. I have disabled web cams internet, wifi you name it been there still no joy.
geposted Mon 23 May 11 @ 1:27 am
audio000 wrote :
Is it just me... I would like to know the people here that have the Denon DN-S3700 , Do you use them
with timecode or with the midi mode..? I like them better with timecode. I have 3 usb ports on my laptop
in did not want to use a powered usb hub with them. But I would like to know what you all do..?
I use them in MIDI mode with Virtual DJ and when I am using Traktor, I use hybrid mode.
geposted Mon 23 May 11 @ 8:37 am
Time code issue. I have my dn-s3700s setup perfectly in midi mode. All the functions work great except the timecode. Both decks play really fast. How do I fix this??? Help please
My setup
Mixer: Vextax PMC 05 Pro III
Audio 4 sound card
2 Dn-S3700's both are set to midi ch 1 & Unit No set all
l
My setup
Audio 4 sound card
l
geposted Wed 27 Jul 11 @ 9:26 pm
My setup
Audio 4 sound card
My setup
Audio 4 sound card
geposted Wed 27 Jul 11 @ 9:29 pm
Paul Cole wrote :
Hi all,
I'm loving my 3700's but having an issue that you might beable to help me with. After about 15 to 30 minutes one of two things will happen. I'll get a crackling distorted sound on the right deck only, or the left deck will freeze up. I'm using midi with the players as a sound card. It's happend while using the computer as a sound card too. I've followed the thread instructions and scoured the forum for an answer but no luck. I'm using vista 32 4 gigs of ram, It's a new computer! any advice would be so great! Hurry! I'm running out of hair to pull out
Thanks,
Paul
Thanks,
Paul
take it from a pc tech VISTA IS JUNK i no this dont answer your problems but vista has alot to do with it
geposted Wed 27 Jul 11 @ 10:16 pm
