Forum: Music discussion
Topic: Controlling Master Volume Output Help...
YakAtakHome userMember since 2010
Hello! I'm a closet DJ and using only the Virtual DJ software to make mixes in MP3 format (no external plug in devices). My problem revolves around the master volume of my recording going high and low throughout my mix. The Gain automatically adjusts, but there are times when the music playing is significantly louder than the mix, and it throws off the "feel" of it.
Where can I go to set a constant Master Volume Output for my recording so the music stays more or less the same loudness throughout (similar to Traktor's option)?
I love this software, but having to constantly lower or raise my volume (or the Gain while mixing) is not ideal.
Thank you!!!
Chris
geposted Sun 13 Jun 10 @ 6:22 pm
