Hello Fellow Dj'ers !! Just a quick question(s).
How many files can VDJ hold in relation to PLAYLISTS & HISTORY tabs.
When just playing around, trying different mixes, I always delete these, as its cloggs up the history tab. Another thing as well, When you rename the files, Can you then drag & drop your favourite folders, ie, A good mix of music played that night, in order to go back & refer to.
Cheers
Cheers
geposted Tue 15 Jun 10 @ 6:46 am
well you can make favorite folders. you can also go into your history to see what you played. you can record and save your mixes with some of the newer skins that have been created.
geposted Sat 19 Jun 10 @ 8:24 pm
