I got a gig finally in a club to do video mixing I want to know what i can use so convert the signal from vga to rca because the club's input is rca
geposted Thu 17 Jun 10 @ 6:37 am
How far do you have to go between your computer and the video input?
a cheap example of a Video signal converter would be:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4779573&CatId=1430
You can probably find something comparable in your area..
but remember, you get what you pay for..
Also distance is a major factor, when you start going past 15 meters, many times the price of getting a clean signal goes up significantly
geposted Thu 17 Jun 10 @ 10:01 am
ok cool. The video input is right in the dj booth. I use to use a wireless system but i got some interferance with the signal occasionally. but thanks
geposted Fri 18 Jun 10 @ 7:33 am
