I have used Cue for 2 years with no problems , I have a HP with a core duo 2.53 GHz NVIDIA 9600gt 512mb video card 3gb ram running windows 7 32bit (a upgrade from Vista) using a Vestax VCI 100 and presonus firebox. I loaded up VDJ 6.1, mapped my vestax to my liking and tested it for 5 hours...all went well...added a plugin or 2 and tried it at the club for 4 hours, all great, may have tried a few more transition effects from this site and then did a Saturday night at the club and out of thin air the key and pitch make a wild change...fast then slow without touching or doing anything.....odd, it then happened again the next night with the same file, thought that was it, just a bad file but then it became random.
I do have a copy of 5.2 cue and vdj 6.1 on my laptop, could this be why? or do i need to just reinstall vdj? I have never encountered this anomaly with this software before, keylock is always set to off.
geposted Fri 18 Jun 10 @ 5:00 am
Are your bpm values jumping up and down even if you sync the decks with the auto sync?
geposted Fri 18 Jun 10 @ 11:14 am
i have used the sync button in the past but when the track starts to slow and speed up there are no changes in the pitch value, this all happens without touching anything, its strange, its almost as if you were pitch bending without touching the vestax wheels, going to wipe it clean and start again. thanks for the post.
geposted Fri 18 Jun 10 @ 12:35 pm
Same thing with mines 5.2 for no reson it will start to draft off even if the bpm is the same after a while of playing i turn norton off my wifi off and malware off it seem like the program act crazy when that happen i have to turn it off and turn it back on to get it back to normal
geposted Tue 10 Aug 10 @ 5:57 pm
