just bought a MacBook Pro and purchased the SL1 box
want to know if it works with virtual dj for the Mac
geposted Sat 19 Jun 10 @ 7:05 am
Unfortunately the SL1 will not work on a Mac because the manufacturer has not released any drivers for it to allow it to be used with 3rd party software. There are drivers for Windows PC only, so if you run Windows via BootCamp you could use it.
The SL3 is not supported on Mac or Windows for the above reason.
geposted Sun 20 Jun 10 @ 2:05 pm
ok thanks jp
geposted Sun 20 Jun 10 @ 7:59 pm
