Hey everyone in VDJ world. I'm lookin into purchasing the denon 3700's and was wondering if anyone could give me some suggestions on what a good mixer to combo them up with would be.
I currently use a numark 200fx with the denon hc4500 rackmount controller. I also do music videos if that matters.
Thanks,
DJ Bo Jett
Thanks,
DJ Bo Jett
geposted Sat 19 Jun 10 @ 3:35 pm
Right now im Using the Pioneer DJM 700 Midi Mixer but im going to get the Denon X1600 mixer. Im using the denon 3700's and They perform really good. Buy from here... The price will be lower than what you see listed in the webpage. I paid 740 for each deck
http://www.proaudiostar.com/
geposted Sun 20 Jun 10 @ 12:33 am
Would you recomend any of the Denon 19 inch mixers? I do alot of mobile gigs, and was wondering if the 500 or the 900 was any good.
I miss using Rane boards, but wow I can't afford it today in this market
geposted Sun 20 Jun 10 @ 3:31 am
I have the Denon DN-X1600 and I highly recommend it.
geposted Sun 20 Jun 10 @ 8:20 am
19's can be a bit of a reach to the decks although I use a DJM 3000 and the Numark AVM 02.
If you have long arms and have the tables at the right height, its no problem.
geposted Sun 20 Jun 10 @ 8:52 am
the 3700's soundcard can be better , but if you use digital output you never willl feel difference with other cd players (cdj2000 for example)
So , it's good to have a mixer with digital inputs .
Denon 1700 , 1600 or Djm 700 are good options in this order .
geposted Sun 20 Jun 10 @ 9:24 am
A 19 inch deck is kind of awkward to go with the denon 3700s. Its really your choice.. The Denon 500 is really good. The 900 has a crossover output for your Subwoofer.
geposted Sun 20 Jun 10 @ 10:58 am
