Hi virtual djs :)
I wanted to set up the transport buttons on my korg nanoKontrol, the ones that has the play stop pause forward wtc symbols on them.. i wanted to set them up to use the browser. However, there is a problem. I have assigned the button to scroll +1 for example, but it is in toggle mode or something, so when i press button it moves once, and when i release button it moves once. So it moves twice each time i push and have no accuracy in choosing the track if you understand :)
I had the same issue on all the other buttons, but changing them to a "note" button fixed it. However i cant change the transport buttons to a "note" button using the korg kontrol editor :( Does anyone know of a way i can disable the transport buttons from executing the script/order twice even though i only press once?
Thanks in advance,
-Steffen
Thanks in advance,
-Steffen
geposted Sun 20 Jun 10 @ 6:58 am
Ok i figured out how to do it. There is a button behavior option assigned to them as well, it has to be set to TOGGLE instead of MOMENTARY then it will work, i presumed this option was for the LED behavior only... stupid me :)
geposted Sun 20 Jun 10 @ 7:46 am
