ok guys I fixed the odd pitch shifting i was getting with the VCI-100, turns out that with VDJ 6.1 the jog wheels on the vci are ALWAYS active, with 5.2 u had to press down until the red led lit up before u could use it, however with 6.1 you can nudge your track by just touching the side at anytime....so far this sounds fine BUT if you work in a club with some good subs the bass vibrates the platters which then sends midi data to the software telling it to move or nudge your track up and down ( sounds like hell)
heres the fix, delete the nudge commands, both nudge - and nudge+ in the mapper.
anyone else seen this issue?
geposted Tue 22 Jun 10 @ 4:48 am
