Hey guys, i got a Dj control steel a couple weeks back and i think i have everything updated correctly but sometime when i use it for a few hour the lights start going crazy and all the knobs i nthe program start going all over the place.
my model of mac is as follows:
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP41.00C1.B03
SMC Version (system): 1.27f2
Serial Number (system): W8824E3NYJX
Hardware UUID: 4A49A069-0579-55CE-932C-30F30E8AC54C
Sudden Motion Sensor:
State: Enabled
and again i use the dj control steel and i'm not sure how to check the versions but i beleive they are up to date, any help is appreciated.
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 800 MHz
State: Enabled
geposted Tue 22 Jun 10 @ 10:24 pm
You can see which version of the driver you are using in the ABOUT tab on the Steel control panel.
The latest driver is always available from the support web site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=226&cid=1
As well, I would recommend you download the latest version of VDJ (5.2.2) from the DOWNLOAD section of this site.
You also may want to look at this document:
http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
geposted Wed 23 Jun 10 @ 6:53 am
I had done that install before but i guess it didn't work properlly, everything looks up to date now. thank you very much :)
geposted Wed 23 Jun 10 @ 9:47 am
