Hey people,
im having a few problems with my timecoded setup and was just out to get some help.
My setup is the following
2 x reloop rmp1 scratch
1 x behringer djx1000
1 x maya 44
1 x hercules dj control mp3 e2
1 x asus g50 laptop
Using serato Scratch live timecoded cds
The problem which im having is the following,
1 Im getting very very low signal at all times (under 10 percent) and sometimes the cd will just randomly start playing backwards
2 - The touch sensitive platter wont allow me to brake and speed up the track, only scratch with scratch mode on.
What could be the cause of these problems
1 x maya 44
1 x asus g50 laptop
geposted Wed 23 Jun 10 @ 8:20 am
heres a screenshot of the setup
http://i305.photobucket.com/albums/nn234/bigmenace324/Unbenannt.png
geposted Wed 23 Jun 10 @ 10:13 am
You are in sound saturation on the inputs. That's why you have a square instead of a circle.
geposted Wed 23 Jun 10 @ 2:26 pm
Try to set down the knob gain..it seems strange anyhow.
Let us know what happens when you do what I am suggesting.
geposted Wed 23 Jun 10 @ 2:49 pm
in the asio config for your maya make sure to drop the volume down on the inputs. you should end up getting them squares into circles
geposted Wed 23 Jun 10 @ 3:22 pm
Alrite ladies and gents, that worked beatifully, now ive only got one more little drama, and that is.
everytime i go to slow down or speed up the track, instead of the pitch staying the same and just the track moving, the pitch bar goes ******* and moves outta pitch like crazy and then 2 seconds later comes back to normal again.
im still using the reloop rmp1 and the behringer djx 750
the settings are as follows on my rmp1 on both
scratch on
pitch range is 8 %
pitch bar whether turned on or off doesnt make a difference,
the only time i can brake and speed up the tracks normally is when i have key lock activated on the rmp1 however, when i slow down the tracks with key lock activated they start stuttering and digitising very very badly.
any one got a clue why it might be doing this?
[Please do not use bad language in your posts.]
scratch on
pitch range is 8 %
geposted Thu 24 Jun 10 @ 5:33 am
This is good advice...thanks!
geposted Wed 25 Aug 10 @ 3:47 pm
