I'm looking for an effect (or sample) to do scratch-exits with.
A biot like the brake effect but then with a needle scrachting noise, just like you wiped the needle arm away abusly.
Anyone know of such thing?
geposted Sat 26 Jun 10 @ 10:09 am
You could just record your own, just use an old needle and do what you want. But I'm sure if you google it youll find that effect.
Huey
Huey
geposted Sat 26 Jun 10 @ 10:14 am
The song "Suat" by De La Soul has the exact sound you're looking for at the beginning of the song plus someone saying "you know we got a party man, get the other record". I cut and pasted that part and use it as a sample.
geposted Sat 26 Jun 10 @ 10:37 am
@Dizzyrocks2001. I'm unfamiliar with the copy and paste to create a sample...I would like to know how this done if you don't mind sharing..Thanks!
geposted Sat 26 Jun 10 @ 10:48 am
I made a typo in my previous post, the song is called "Squat". Just play the track in VDJ and use the sampler to record the section of the song you want and save it.
geposted Sat 26 Jun 10 @ 11:46 am
crap, i never thought of using tha sampler to record.
honestly, i record samples using the main record feature and save them to my desktop then add them to the library.
never mind, i know now.
geposted Sun 27 Jun 10 @ 2:50 am
