Hi all,
I can't find a way to select all files in the browser. The only way is with the Ctrl-A button from my keyboard.
Can I use a button-action (in a skin) for this, something like "browser_select_all" ?
Best regards,
John
Best regards,
John
geposted Sun 27 Jun 10 @ 1:11 am
Nobody???
geposted Thu 01 Jul 10 @ 1:02 pm
djjb wrote :
Nobody???
I guess I'm having trouble trying to understand why you need something faster and simpler then CTRL-A ?
HECK, until you posted it, i never even thought of using CTRL-A
for years now I have always just selected the first song then scrolled down and shift-selected the last song..
Since I rarely need to select ALL the songs in the browser, this isnt much of an issue for me ;-)
geposted Thu 01 Jul 10 @ 1:21 pm
I use a touchscreen and I only use the keyboard for search. But for 95% I don't search.
So.. when I start a gig I simple browse the map I want and select all songs and drop them into the playlist.
All the rest is going on screen.
This isn't a big problem for me to. But when I can create a skin-button for it, that would be cool..
Thnx for your reply,
geposted Thu 01 Jul 10 @ 3:14 pm
