can someone please tell me if theres an app for mapping the mp3 e2? also whats the best options for mapping it for use as an fx unit only? thanks, john.
geposted Sun 27 Jun 10 @ 2:47 am
Its already mapped to vdj. In vdj you can modify the default mapping to whatever you like.
geposted Sun 27 Jun 10 @ 7:06 am
Hi all!
need some help!
does anybody knows what command had the Dj Console STEEL, in the Mapping, for the button SHIFT? (shift - is the button that converts the 6 sample buttons, into 12)
I have now the RMX console, and I want to change the SOURCE button values, 2 do exactly what SHIFT button was doing on STEEL console.
how can I mapp it?
thank you!
need some help!
how can I mapp it?
thank you!
geposted Fri 27 Aug 10 @ 12:36 pm
