I'm new to VDJ and I'm having a problem with the "Skip Beat" function with the arrows (located next to the "Seek" function which also has arrows).
After I sync the songs that have the same BPM and hit the Skip Beat arrows to change the order of the little blue and red squares, they will NOT stay lined up. Like they used to stay aligned right on top of each other, but now they are falling in between each other which is making the music sound off beat. I must have pressed something so that they won't stay aligned anymore even after I press sync. Does anyone know how I can get them to stay aligned again?
Skin I'm Using: Mix Lab V3
geposted Sun 27 Jun 10 @ 1:28 pm
Nobody will help you, unless you become a registered user!
You have to pay to play my friend.
geposted Fri 02 Jul 10 @ 9:28 pm
not rue living we all try to help anyone here if we can.
try when you get them lined up to keep hitting the sync button until your mix is done.
or the beat match button which i dont use so maybe someone else can chime in.
geposted Sat 03 Jul 10 @ 6:15 am
You are probably running and old and out of date version of the software. There was a bug in an early version of v6 that did exactly what you describe. This was fixed in the next version.
Please try the latest trial https://virtualdj.com/download/trial.html and if you like the software, please purchase it https://virtualdj.com/buy/
geposted Sat 03 Jul 10 @ 4:54 pm
