Hey guys. I'm thinking of getting a mac but with all the news abt VDJ running badly on macs, I decided to do my homework first.
Borrowed my friends mac which he just bought and downloaded and installed the trial version of VDJ. I ran it and although it seemed to work pretty fine, I noticed that the waveform was pretty jerky. I thought it might be a performance issue, so i tried tweaking the performance settings, but to no avail. It remained jerky all the while.
I thought it might be an issue exclusively with his macbook so i went down to a mac store and downloaded the trial version on two of their macbook pro's and tested it out. Still the same problem. Very jerky waveforms.
Is this a known issue with the mac version and is there a fix coming up soon? I was on the verge of getting a mac today, but decided to check this out first. Thanks in advance.
geposted Mon 28 Jun 10 @ 9:59 am
The jerky waveforms are a known issue apparently. They don't however affect the music at all on my mac. I never trust the waveforms anyways, because your ears should be the focus. I know the mac version is still being worked on. I have no serious problems with my version.
geposted Tue 29 Jun 10 @ 11:30 am
Hi sonance, at the codec tab changed the internal default to QuickTime audio for mp3. I will pm u soon. Sorry just back from Koh pah nhan. Saw your pm. I might going to Bandung this weekend so will try to reply before I go.
Regards;)
Regards;)
geposted Wed 30 Jun 10 @ 7:38 am
DJMario: Thanks much dude. Glad it doesnt affect the music but its a bit annoying seeing it so jerky. if u know what i mean.
SpinnaJ: Thanks very much bro. Will try that out. Will be getting my macbook pro next week. Haha. Glad ure going all over the place man. Have an awesome time in bandung! Remember to take pictures! :P
geposted Wed 30 Jun 10 @ 1:58 pm
Hey SpinnaJ. Ive tried doing what u suggested. Waveforms are still jerky. I just got my Macbook today. These are the specs.
Macbook Pro 15inch
i5 Processor 2.4Ghz
320GB harddisk
4GB Ram
Are there any other suggestions to fix this? Thanks bro.
Macbook Pro 15inch
i5 Processor 2.4Ghz
320GB harddisk
4GB Ram
geposted Thu 08 Jul 10 @ 12:19 pm
Hi bro, sorry late respond. I hv a MacBook pro same as yours too. Do your waveform still jerky? Using which skin? Sorry cos on my Mbp, the jerkyness is minimal and don't really notice it.
Regards;)
Regards;)
geposted Tue 20 Jul 10 @ 10:02 pm
