After a song plays, is there any way that VDJ can clear off the last played song in the deck. (so the deck opens up and I can drop the next song)
Thanks Robert
Thanks Robert
geposted Mon 28 Jun 10 @ 1:39 pm
Depends on the skin you use, some have an unload button built in. You can also assign keyboard shortcuts to unload deck 1 or unload deck 2 if you wish. There's no real advantage though as one song just replaces the previous one in normal use.
Keith
Keith
geposted Mon 28 Jun 10 @ 3:14 pm
Thanks Keith, I know about the unloading on the keyboard and on my skin, I just wanted VDJ to unload the song after it was played automatically.
geposted Mon 28 Jun 10 @ 4:46 pm
Sorry, it it is not possible to do this automatically. Most users simply load the next song on the deck once the previous one has finished.
The only way to completely unload a song from a deck is via keyboard shortcut mapped to unload or a skin that has an unload button.
geposted Wed 30 Jun 10 @ 12:33 pm
Thank you. (Just thought it would be good to have.)
geposted Wed 30 Jun 10 @ 12:43 pm
