Hey fellas,
I have an RMX running VDJ on a PC lappy. I also have my iMacs audio (software instruments controlled by MIDI) on one of the RMX inputs and I have to switch the source to get the Macs audio output. I would like to have all 3 audio outputs available to me all the time. I dont need to record the audio from the iMac yet but it may be something that I would like in the future. This is where my question comes in. What would I need to add to my set up in order to achieve this? Any and all advice is appreciated!!
geposted Thu 01 Jul 10 @ 12:13 am
Currently, VDJ can only use 2 sources at once: either audio files (internal sources) or external sources. For each deck, you have to choose which source, as you've noticed.
Until VDJ comes out with a way to support more than 2 sources, your best solution right now would be to use a mixer, and route your different sources (Rmx, iMac, etc) to it.
geposted Fri 02 Jul 10 @ 6:54 am
