I have just bought a Hercules deejay trim sound card, Serato's box was unreasonably expensive, and got serato timecode vinyls. I have yet to make anything work... I cant get a 100% timecode signal...only about 1-5%. Can anybody help!!?! I have tried everything to get the signal to 100%. I did buy numark's virtual vinyl hoping that would fix the problem, but they will not be here for another week. ANY SUGGESTIONS?!?!
2 stanton t-62
numark c3 usb mixer
hercules deejay trim 4 and 6 sound card
serato blue timecode vinyls
2 stanton t-62
numark c3 usb mixer
geposted Thu 01 Jul 10 @ 12:23 am
Did you follow the recommendation of the user manual regarding the configuration of the timecode (page 10 to 12)
http://ts.hercules.com/download/sound/manuals/Trim/vdjLE/01_VirtualDJ_6_LE_TC_English.pdf
geposted Fri 02 Jul 10 @ 6:59 am
I have followed instructions from Virtual DJ and Hercules completely! I also did all software updates. I have yet to receive the virtual vinyl...I am hoping that will do the trick.
geposted Fri 02 Jul 10 @ 5:47 pm
OK I screwed up! The computer I was using was not powerful enough to process the timecode signal. Using a computer that DOES NOT meet the requirements to run VD will cause many and endless problems...
geposted Sun 04 Jul 10 @ 12:08 am
One question: How did you do the software updates without entering your VDJ serial number in your profile ?
geposted Mon 05 Jul 10 @ 6:32 am
I didnt need any updates for VD only for the hercules deejay trim. I bought VD and the hercules sound card seperately.
geposted Thu 08 Jul 10 @ 1:09 pm
Then it's very easy. If you don't make updates - then you must live with the bugs.
Heiko
Heiko
geposted Thu 08 Jul 10 @ 4:02 pm
