I hvae recently just purchased a mac and installed VDJ Pro 5.2 for mac, however when i am trying to scan files into program it is not scanning them all.
Can anyone help ?
Can anyone help ?
geposted Thu 01 Jul 10 @ 6:40 am
Hi, v5.2 is old by now.. We are on v6.1
Please try the trial version from these site while evaluating.
And if you like the product, do support it by purchasing it.
I hope to see you with us soon.
Regards;)
Spinna J
Regards;)
Spinna J
geposted Thu 01 Jul 10 @ 6:52 am
Spinna, thanks i will look at newer version. However do you no if i will i have the same problem with newer version. I mean could there be certain files the mac / vdj doesnt like from my harddrive.
geposted Thu 01 Jul 10 @ 7:44 am
Hi, with regards with the new version, it have a lot of improvement.
Try to add the songs to database on Vdj.
geposted Fri 02 Jul 10 @ 8:52 pm
I have noticed that when adding songs to the database it will only look into files like one deep. Say have a rock folder, then inside that artist folders, then album folders you will need to go into the artist folders and add to the database that way. I have found that just adding the rock folder will not get everything deeper inside. Sorry not a computer guy so that is the best way I can describe it. That is what I personally have found and how to get around it. Hope it helps.
geposted Tue 06 Jul 10 @ 8:49 am
