Okay here's another one for you to help me with and it this one is important,
I set my cue at the beat and many times when I hit play it's not right where I placed the cue, so I have to do a little juggle of cue and play until i get the best and can throw the mix, I never know when it is on or off the correct cue as the time and all postions are correct...I use a Denon 4500
Many thanks!
Many thanks!
geposted Fri 02 Jul 10 @ 11:31 pm
Also...it only does this when one side is playing in other words it stays on cue if the other side is paused or stopped....
geposted Sat 03 Jul 10 @ 1:35 am
There's a function called deck 1 smart_ play or deck 2 smart_ play. If this is enabled, It causes the problem you mention. It appears as a small padlock on the Pro 1024 x 600 skin just above the play button
geposted Sat 03 Jul 10 @ 7:45 am
Alan...Many thanks!
I fixed it by resetting factory defaults but still didnt know what caused it, I didnt know what those little lock icons meant.
geposted Tue 06 Jul 10 @ 5:36 pm
