When one analyzes a song in VDJ, VDJ finds the key of the song and put it in this format e.g. Em or F#m etc.
Is it possible to change it this other format 10A, 11B etc.
Thanks in Advance
Thanks in Advance
geposted Thu 08 Jul 10 @ 3:57 am
If you use the default skin, just click on the display area where it says E# etc, and it will change to 1a etc.. :)
geposted Thu 08 Jul 10 @ 5:56 am
thanks..
I must be having a blonde moment then.. cannot seem to get this work..
is there a VDJ for dummy kind of instruction available.. I feel like I am back in the school...
geposted Fri 09 Jul 10 @ 3:04 am
What skin are you using ?
geposted Fri 09 Jul 10 @ 5:40 pm
Logan18
In the VDJ Browser Window (where all of your songs are listed), rightclick on the menu line at the top, and make sure that Key(numeric) is ticked, then you can sort them by this.
geposted Fri 09 Jul 10 @ 6:00 pm
haydos you are a legend bro... thanks to all to help me out here.. all sorted
geposted Sat 10 Jul 10 @ 12:59 am
no worries mate.
i saw on another post that you know a bit about VDJ code.
Maybe you could have a look at my question here.. :)
https://virtualdj.com/forums/131080/General_Discussion/Special_VDJ_Mapping_Code_for_CDJ900_2000.html
geposted Sat 10 Jul 10 @ 10:29 am
