Hi all,
I have bought Behringer BCD 3000. It works with Virtual DJ nice, but there's one problem. For example, I have to hit play button twice to play the track (the same at other buttons like "Kill" effects and other). And the same when I want to stop the track. Does any one know how to solve this problem? You know, hitting buttons just once :)
Thx for all replies
Thx for all replies
geposted Thu 08 Jul 10 @ 2:44 pm
Are you using VDJ Pro or LE?
What version?
What version?
geposted Thu 08 Jul 10 @ 4:11 pm
Please try it with the latest v6.1 trial https://virtualdj.com/download/trial.html
geposted Thu 08 Jul 10 @ 10:39 pm
to hippydog: I have version 5.0 rev 6
to jpboggis: I tried that trial and nothing. Still need to hit twice.
Btw sometimes happens, that in the middle of the track, track stoppes playing and I have to restart Virtual DJ.
geposted Fri 09 Jul 10 @ 4:39 am
You are using an out of date version of the software. Please upgrade to v6.1
There have been many changes, bug fixes and improvements to the software since v5.0.6 - Please see https://virtualdj.com/wiki/VDJscript.html
If you have not purchased VirtualDJ then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
In v6.1 trial, make sure that the BCD3000 is connected BEFORE starting VirtualDJ, otherwise go to CONFIG -> Mappers, click on the button to the right of the drop-down list and choose to rescan for connected devices.
Also, make sure that you have the latest drivers/firmware from Behringer installed: http://www.behringer.com
Also, check that your sound settings in CONFIG -> Sound Setup are correct.
NOTE: The BCD series of controllers can cause issues when using the internal sound card, due to bad design of this hardware. Turning off wireless networking may help, as will using a different sound card instead of the one built into the BCD.
geposted Fri 09 Jul 10 @ 12:16 pm
