Hi,
recently I switched laptops for an outside gig. Now I switched back and all of my Virtual folders are gone. How can I get them back?
geposted Thu 08 Jul 10 @ 10:05 pm
Where are these folders saved so I can try and find them? They all got deleted some how.
geposted Fri 09 Jul 10 @ 12:58 am
Wow, I lost my cue points, my comments, my linked videos...what did I do!
geposted Fri 09 Jul 10 @ 5:15 am
did you uninstal vdj ?
the virtual folders, comments etc are contained into an xml file.
"VirtualDJ Database v6.xml"
located in your "documents/virtual dj " folder
be sure to backup this file regulary, in case of crash or other trouble you can recover all by overwriting the existing one...
geposted Fri 09 Jul 10 @ 6:01 am
If U Have Not Clean Your Cp You Can Get That Info,And All Ways Back Your Info Up With Your Music On A Zipp Or Something,That Help For Me.
geposted Fri 09 Jul 10 @ 10:03 am
oh, also makes sure that you don't change the path to the music files... or vdj will assume this is new music...
geposted Fri 09 Jul 10 @ 12:45 pm
I think I have deleted it with an overwrite. I do have 5.02 XML file that has all of the cue points. How do I transfer this to version 6.08?
geposted Sat 10 Jul 10 @ 10:53 am
I Think all you need to do is Copy the one you have and rename to 6.xx, then open 6.8 and done....
Good Luck
Joey....
Good Luck
Joey....
geposted Sat 10 Jul 10 @ 6:28 pm
