There's no reason it should be doing this, I've ran it dozens of times without fail.
I read that updating the drivers messes up the software.
What doo?!
cheers.
What doo?!
cheers.
geposted Sat 10 Jul 10 @ 5:45 pm
What controller are you using?
geposted Sun 11 Jul 10 @ 3:58 pm
Ahaha, really sorry.
Hercules RMX controller. I'm using Windows 7 and the VDJ version that came with the controller.
Here are my specs. When I have the controller plugged in, it shows up in device manager, as well as DXDIAG, so I don't know what is making it not show up for VDJ.
Thanks for any help :]
System Information
Time of this report: 7/11/2010, 21:19:05
Machine name: ENTERPRISE-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP G60 Notebook PC
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz (2 CPUs), ~2.1GHz
Memory: 3072MB RAM
Available OS Memory: 3004MB RAM
Page File: 1235MB used, 4768MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
System Information
Memory: 3072MB RAM
geposted Sun 11 Jul 10 @ 11:21 pm
Simply download and install the latest driver (2.HDJS.2010) from the Hercules support site:
As well, resgister your VDJ serial numbber in your profile, and you'll be able to download the latest update for VDJ LE (5.2.2) which is also necessary if you want to use it under Windows 7.
geposted Mon 12 Jul 10 @ 6:06 am
hey, dubzob-- did that work for u? cause it certainly didnt for me...
geposted Tue 13 Jul 10 @ 3:23 am
nope, not yet.
kind of bogus, i paid for this thing i really wish it would work.
geposted Sat 17 Jul 10 @ 4:23 am
Update:
Something happened and now instead of not detecting the controller, there's an error with my ASIO sound driver. I guess this is progress, eh?
OPTIMISM!
So I googled and found loads of sites for ASIO drivers and installed one or two but none worked. More advice for sad newb? Thank you guys, in advance. Hopefully :]
OPTIMISM!
geposted Sat 17 Jul 10 @ 5:25 am
Your problem is that you are not following the proper installation instructions - you don't just go load 'any' driver.
Uninstall ALL drivers you have tried.
Uninstall the Hercules drivers if you ever did load them.
Uninstall your LE software.
Unplug your controller(s)
** Restart **
Now go download the latest Hercules drivers from their site - http://ts.hercules.com (These are the only drivers you need)
Follow the instructions during the driver install - if you do anything out of order then you will most likely have to start from scratch - again.
Once you have your controller installed - now you can install VirtualDJ.
geposted Sat 17 Jul 10 @ 11:43 am
