So i decided to try the "Burn CD" option in my program today. I tried not to go over 75 minutes so that it would successfully burn.
However, it saved as a .bin file, and a .cue file. Now how do I turn this into a music CD?
Any help would be appreciated.
geposted Sun 11 Jul 10 @ 1:40 pm
You need a Burning Software like Nero or any other Burningtool which supports .bi/.cue files. It's a very solid and popular format of storing Images for burning.
You could try http://www.imgburn.com - It's free.
Greets, Heiko
Greets, Heiko
geposted Sun 11 Jul 10 @ 1:46 pm
ok, I moved the files over to my laptop which has nero.
now will this file find a way to turn into music? Or do I have to find a converter program somewhere??
geposted Sun 11 Jul 10 @ 8:28 pm
When you burned it to CD it will be a normal (Red Book compatible) Audio CD.
Just open the .cue file with the Nero 'Open file' dialog and burn your CD.
Greets, Heiko
Greets, Heiko
geposted Mon 12 Jul 10 @ 1:37 am
THX.
I burned the disc the other day. JUST BEFORE MY LAPTOP DIED.
Well not died, but the video card went out on my Alienware. I bought it for a gaming laptop. so I'll probably have to buy another laptop soon
geposted Thu 15 Jul 10 @ 4:11 pm
