I would like to control the parameters of the filter effect withe x-y pad. Is that possible?
geposted Sun 11 Jul 10 @ 11:34 pm
I thought I read something about this in "Hardware Forum", https://virtualdj.com/forums/101537/Hardware_Technical_Support/Korg_Nanopad_X_Y_pad_configuration.html, https://virtualdj.com/forums/111696/Hardware_Technical_Support/VDJ6_Using_Korg_Nanopad_as_a_midi_device_.html?page=1, http://fr2.virtualdj.com/forums/107577/PC_Version_Technical_Support/how_do_i_map_touch_pads_for_effects_.html, heres a few I found using Google, hope they help.
Huey
Huey
geposted Mon 12 Jul 10 @ 12:03 am
Here is how I did it
Y "effect default slider 1"
X "effect slider 2"
For this to work you have to activate the effect by pressing the pad you mapped it to.
X "effect slider 2"
geposted Mon 12 Jul 10 @ 4:42 pm
Thank You Gents for your help
geposted Wed 21 Jul 10 @ 12:52 am
