Has anyone else bought this controller and has it working with VDJ on a Mac?
I have a 13" 2.4ghz dual core MacBookPro with 4 gigs of ram and use it with VDJ, Serato ScratchLive, and Serato Itch with very good results.
I just picked up the Ion Discover DJ controller and tried to use it with VDJ 6.1, but the program does not see the controller as a native one. I can map functions to the units controls, but shouldn't the new version see the unit and use the proper map automatically?
The unit has a sticker on the bottom with "April 2010" on it. Could there be a firmware difference with the newer models?
Also, when I have the "Show connected hardware only" selection on in the Mapper tab in the config screen, I have the Mapper for the Denon HC-1000S on the drop down list along with Keyboard and Standard wrapper. Is this a default mapper selection?
The unit works fine with the packaged software (Mix Vibes Cross Dj), but I bought it because it was listed as a supported controller for VDJ.
I posted this info in the Mac support forum earlier today, but thought about it and figured maybe it should be in this forum instead.
geposted Sun 11 Jul 10 @ 11:46 pm
geposted Mon 12 Jul 10 @ 5:25 am
thanks, now where do i put it?
geposted Mon 12 Jul 10 @ 12:38 pm
In your VDJ Folder under the subfolder 'Devices'.
Greets, Heiko
Greets, Heiko
geposted Mon 12 Jul 10 @ 12:44 pm
Thanks for the quick responses guys. The controller was recognized right away. Not that bad a controller for the price.
geposted Tue 13 Jul 10 @ 12:09 am
hey I have the same problem but i am using a trail version so i cant access the update is their any other way of getting the update or could someone send it to me some how ?
geposted Tue 27 Jul 10 @ 7:31 pm
Sending Controller and Skins to no license users is not allowed. Sorry.
Maybe with the next upcoming Demo Version.
Greets, Heiko
Greets, Heiko
geposted Wed 28 Jul 10 @ 7:33 am
how come it won't let me download
Sorry, you don't have the necessary accreditations to view this page.
geposted Thu 16 Feb 12 @ 6:41 pm
It's because this add-on is obsolete and no-longer available.
This topic is nearly 2 years old and the Discover DJ is natively supported by the latest VirtualDJ Pro v7.0.5b.
No custom mapper is necessary. Please download the latest VirtualDJ Pro from http://www.virtualdj.com/download/updates.html
[Old topic locked]
[Old topic locked]
geposted Thu 16 Feb 12 @ 7:57 pm
