I am using a Numark Total Control MIDI controller, and have had no complaints at all. However, since I installed 10.6.4 OS on my MacBook, VDJ takes about 3-4 minutes to load up, and when loaded, now doesn't recognise the NTC which stays dormant, as if it doesn't work. I am running VDJ Pro 6.1. Any ideas? Cheers
geposted Mon 12 Jul 10 @ 12:33 pm
Well depending on how savvy you are I would recommend backing up your data, wiping the drive and reinstalling the OS...run updates, reload music and pictures, etc....then you should be good. No matter what OS you have windows/mac there will always be remnants of junk/crap files that simply take up space and rob performance.
geposted Tue 13 Jul 10 @ 9:20 am
