hello all ,
I am using windows vista 64 bit. I was using some very idiot application, it made my gadgets disapper in wondows sidebar :-/ . Please suggest me how to make my mini applications display in windows sidebar.
Thanks in advance !!
geposted Fri 16 Jul 10 @ 5:12 am
Search for 'sidebar' in your start menu. It should open back up when you click it.
geposted Fri 16 Jul 10 @ 2:33 pm
// gadgets disappear in windows sidebar //
Hhmmm, why don't you run a setup for sidebar or try restore your system..well if both of these wont work,try some tools that optimizes windows . they definitely have such tools . I can suggest you advanced system optimizer (http://download.cnet.com/Advanced-System-Optimizer/3000-2094_4-10147659.html?tag=mncol) . use this link to download it :-)
As its a best optimizer , run it open PC fixer ...
Go to PC fixer -> list problems -> Desktop -> mini applications in windows sidebar are not displayed correctly.
Your feedback are welcome pear !!!!
geposted Sat 17 Jul 10 @ 3:35 am
