Hello. I was playing videos in between band sets. When I went back to play behind the band I pressed the play button on the TC and nothing happened. I tried & can tell every button on the Total Control responds with exception of the play button. Music/videos load and everything but the muusic or video does not play at all.
I do see the TC skin reponding to the buttons. Also, if I press the play button and then attempt to close VDJ I get a warning window saying "The music is still playing! Are you sure you want to quit VDJ". Once again zero music is playing and/or you can't hear it.
My thoughts are that maybe the play function on the mapper went south so I went to config, mapper tab and under "key" this is how it's listed:
the play "play_3button" , cue "cue_3button" & pause "pause_3button".
Not sure what is going on but hope someone can assist!
Thank You!
Edwin
"DJ WiN"
Thank You!
Edwin
"DJ WiN"
geposted Fri 16 Jul 10 @ 7:40 pm
Hello, does the button work in other software?
Did you try testing it with midi OX?
geposted Tue 27 Jul 10 @ 8:45 am
Check your Audio Configuration in VDJ. I know sometimes with mine if it's not correct my total control will do the same as yours is doing.
geposted Tue 27 Jul 10 @ 10:25 am
