Topic: Upgrade Question
I am a limited edition user and my software is registered. My upgrade discount is $50. I am currently considering whether to purchase a used Hercules (software already registered) or new "retail" Hercules DJ console RMX which comes with VirtualDj LE and that upgrade discount is $149. If I go with the new Hercules will my total discount be $200 off the retail for the Pro version? I need to know because I see alot of low cost, used Hercules rmx's out there and depending on my total discount it maybe smarter and less to get a used one and pay $250 (with my limited edition discount) for VDJ Pro, than for a new Hercules with it's own discount VDJ software.
Thanks in advance for your help.
Mack
geposted Sun 18 Jul 10 @ 12:51 am
The discount works with only one serial number. So with your RMX it's about 149$ discount and with your Atomix MP3 it's about 49$ discount.
if you buy a used rmx or any other used controler , and if the software that come with it is already registered you'll can't use the serial numlber to get a discount...
What if the controller is registered but the upgrade discount is not used? Can the upgrade discount still be available?
[Please don't quote the post right before your message - This is unnecessary and also makes your message more difficult to read when the quoted text is not properly distinguished from your own reply.]
If the upgrade discount has not been used then yes, it will still be available. This can be obtained by entering the serial number on the purchase page https://virtualdj.com/buy/
Only one discount can be used off the full price of VirtualDJ Pro (I.e: You cannot combine two or more to receive more discount.)
