Hi everyone I was wondering if there was an option in VirtualDJ to allow me to have CD mode enabled but have the platters used for scratching (similar to the Hercules Scratch On effect). The reason being is because for some reason the program keeps scratching songs by itself when I load them up. (Not good for gigs) I have a great computer but I guess its not good enough. Thanks for the help!
geposted Sun 18 Jul 10 @ 6:29 pm
Hello are you using V6.1.1 I would recommend using it for best performance with the NS7.
I have not heard of any scratching issues on load previously.
Its not possible to scratch when the motor is turned off currently its mapped as a toggle between motorized scratch and CDJ jog mode.
You could edit the mapping manually for this however if you wanted.
geposted Thu 29 Jul 10 @ 11:40 am
