Apologies for the start of this topic which has been covered countless times across this forum but I found that after trying every suggestion I was still stuck.
I purchased 6.01 Pro
I use a Samsung R20 plus Laptop and a Hercules Rmx to control VDJ.
I also Purchased a creative X-Fi Go Usb Soundcard (I was told i needed another soundcard to use the headphones)
I Run my laptop into a 2 channel mixer from the headphone port on the X-Fi
My Config goes
Input; none
Output; Headphones (Master : First Card / Headphones : Second Card
Sound Card; 2 Soundcards; Speaker (SB X-Fi Go!)
Speakers (Hercules DJ Console Rmx)
(Also tried with different combinations of my available soundcards)
Now....
When I open up my Playback devices from my taskbar while i have two track playing on VDJ, Both playback devices in the window (hercules DJ console and the X-Fi) Show Volume in the green bar to the right.
Could this mean that the problem is with the laptop soundcard setup and not with the VDJ setup?
Tried to make this as simple as i could any help would be greatly appreciated...
My Config goes
Input; none
Now....
geposted Mon 19 Jul 10 @ 9:13 am
Who exactly told you another soundcard was necessary ?
The Rmx inclues a soundcard to which you can connect both your speakers/mixer (Output 1/2) and headphone. Simply configure VDJ as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console Rmx
BTW, you should enter your VDJ serial number in your profile, whihc will allow you to download future updates.
- Input : None
geposted Mon 19 Jul 10 @ 9:53 am
Sorted! thanks man.
pretty obvious now....
sorry for the bother.
geposted Mon 19 Jul 10 @ 10:37 am
