i recently created a playlist with netsearch songs. Aparently, everytime i open virtualDj again the songs still in the playlist but the names (who are really useful) are being replaced by numbers (Ex: e37748909) i would like to see the playlist as i created it at the begining with names and stuff. Does somebody have a solution, or perhaps the same problem? i bougth the subscripcion and if i cannot use netsearch for playlists does not make sense then.
geposted Tue 20 Jul 10 @ 1:14 am
i don't have these problems
everything works great with virtual dj 6.1
geposted Tue 20 Jul 10 @ 4:18 am
i downloaded each song to the cache and it works fine.
thanks anyways :)
thanks anyways :)
geposted Tue 20 Jul 10 @ 10:34 am
no problem ;o)
geposted Tue 20 Jul 10 @ 10:51 am
i have the same problem
geposted Wed 22 Sep 10 @ 7:13 pm
download the demo then subscribe to the service
or, https://virtualdj.com/contact/
geposted Thu 23 Sep 10 @ 6:03 pm
Same problem here.
more details on my problem:
If i download to cache in the same session , the filename will have "artist-title" info But if i stream a song and did'nt download to cache and later go to history node, all i see is the "id" of the song. Nothing change (i won't have (no artists Title info) if i download to cache from history.
i assume the song id (ex: yt - g9HDyaCTlI) is the ID from Grooveshark ? am i right ?
i tried searching that id on grooveshark web site but no result..
Anyone with information about that ?
I own VDJ PRO 7 and i have a Premium Membership.
Thanks
Thanks
geposted Sun 17 Oct 10 @ 12:41 pm
I have the same issue with the same set-up. It came in looking just fine, I save the play list, shut down and rebooted it was al codes.
Also, how did you download to the cache.
Has any figured out how to use a groove shark playlist on VDJ? I ended up retyping it for tonight.
Happy New Years all.
geposted Fri 31 Dec 10 @ 10:43 am
You will need to cache the files first and then add the cached versions to the playlist.
To cache, right-click on the file in the NetSearch results and choose this option. Once the download is complete, go to the NetSearch folder and add the cached file to the playlist.
Files must exist on disk to be used in a playlist.
geposted Fri 31 Dec 10 @ 5:16 pm
