Hi guys just a quick simple question.
My F1 key Activates my sampler but what i want to do is change how it responds.
I want it to work when i keep my finger on they key then stop when i release my finger instead of having to press once to play and another time to stop.
Thanks in advance
Thanks in advance
geposted Tue 20 Jul 10 @ 11:03 am
I believe its "down ? Sample 1 play" or " down ? Sample 1 play: sample 1 stop". I'm not at my laptop right now, sorry.
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 20 Jul 10 @ 11:25 am
Hi just to let you none of the above worked.
Thanks
Thanks
geposted Tue 20 Jul 10 @ 12:04 pm
Doesnt matter i have managed to figure it out with the information you gave me.
Thanks dude.
Thanks dude.
geposted Tue 20 Jul 10 @ 12:08 pm
Well sorry I wasn't more of a help but could you post the script cause maybe others are running into the same problem.
Huey
Huey
geposted Tue 20 Jul 10 @ 2:25 pm
