ok so i bought a Hercules Steel, and its great, but my trial for pro ran out, so i figured id buy home edition because there was a few features I don't need from pro, and now i cant control VDJ with the Hercules. is there a plug in ill be missing or something that i dont know PLEASE HELP.
geposted Tue 20 Jul 10 @ 3:46 pm
Home Edition doesn't support the Hercules controller; the version you should use is the LE version that came with your controller. The Pro trial is only a trial - the limited version it came with should still work.
geposted Tue 20 Jul 10 @ 4:20 pm
So, I have a choice between using Pro Or the LE which can not record or use skins or anything. that's a real pain.
geposted Wed 21 Jul 10 @ 3:13 am
As far as recording is concerned, it was added with the update (v5.2.2, available in the DOWNLOAD section).
No luck for skins though...
geposted Wed 21 Jul 10 @ 6:02 am
It's not a pain at all. You bought a controller which comes with a limited version of the software - it's not advertised as including the Pro version. If you want the full pro functionality then you have to buy the software - and you even get a discount for having your existing software :)
geposted Wed 21 Jul 10 @ 7:36 am
The money you spent on the Home edition can be used towards purchasing the Pro version..
OR You can also use your LE code to give you a discount.. (which might be greater then then What you paid for the home version!)
geposted Wed 21 Jul 10 @ 10:47 am
I just got the hercules mk2 v2 and i have an updated version of virtual dj 5.2 but the controler is not working with it does anyone have an answer for this problem? PLEASE HELP
geposted Wed 21 Jul 10 @ 8:32 pm
Did you use the lastest driver?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=177&cid=1
What do you mean with not working?
geposted Thu 22 Jul 10 @ 6:29 am
i got the hercules mp3 e2 & i got virtual dj pro.now my controler is not working.
HELP ME!!!!
HELP ME!!!!
geposted Thu 12 Aug 10 @ 1:01 pm
HELP ME!!!!
HELP ME!!!!
What version of VDJ pro are you using?
geposted Thu 12 Aug 10 @ 1:18 pm
6.0.1
geposted Thu 12 Aug 10 @ 7:43 pm
jinge WELCOME as a Pro user:)
geposted Fri 13 Aug 10 @ 5:04 am
ditto on that!
geposted Fri 13 Aug 10 @ 9:53 am
