I still cannot get the cover images to pop up on my tracks when I flip through them.
I've got a few CD inserts that I would like to attach to the tracks, but it won't seem to work.
The only options I have is what they can find through google, rhapsody or amazon. this just won't do.
Any help?
Any help?
geposted Wed 21 Jul 10 @ 8:39 am
I have just found the issue I believe. The files that I am DL'ing from Traxsource are in .wav format. When I Dl'ed a few .mp3's from traxsource, I have the image without an issue.
What I need to do is figure out how to make those images into a tagged variant.
any suggestions?
any suggestions?
geposted Wed 21 Jul 10 @ 9:30 am
.wav's do not support tags, which means they cannot have embeded artwork.
Roy
Roy
geposted Wed 21 Jul 10 @ 10:39 am
Ah.
thanks a lot
thanks a lot
geposted Wed 21 Jul 10 @ 11:18 am
I think you may create your artwoks for your wavs by creating images with tha same filename.
Example You have a song Artist-Title.wav
Create an image with name Artist-Title.wav.jpg and place it in the same folder with the song.
Then open VirtualDJ and you will have your artwork there.
It works with the mp3s, i think it works with wav too. Try it.
geposted Wed 21 Jul 10 @ 1:25 pm
