Is there a skin command to display cover art when designing a skin?. Is it possible to have your bass or mid eq crossfader to auto fade or sync with audio crossfader ?. Thanks
geposted Thu 22 Jul 10 @ 6:48 am
You do have the option to show cover art in your browser. There should be a bullseye looking button next to the search bar. Click that and you should see it.But as far as the eq's fading with the crossfader sure you'd just have to map it out with buttons or the crossfader. I think somewhere in the General forum there is a guy who has keyboard shortcuts mapped out that do just that.
Hope this helps
Huey
Hope this helps
Huey
geposted Thu 22 Jul 10 @ 9:32 am
