Are there any reported errors with this version of windows. I'm just replaced my trust old Toshiba Satellite with a spanking new one and I'm struggling playing mpegs. they play ok in WMP but wont play in VDJ???
geposted Thu 22 Jul 10 @ 2:55 pm
mpegs as in mp4s... or mpg files ?
I run that version with no issues..
what is happening ?
what is happening ?
geposted Thu 22 Jul 10 @ 8:30 pm
Same here. It just says Error when I try to play .mpg (MPEG4) files in Virtual DJ. They play in windows fine. I had to install a codec on win XP to get them to work, but the codec I have won't install under win 7 (it's one of those you have to right click on then go to "install" in WinXP, but win 7 doesn't have that option?
Any ideas?
Thanks
Any ideas?
Thanks
geposted Sat 16 Oct 10 @ 10:42 am
Did you happen to move those mp4s to a different folder on ur hard drive?
I never had to install any codecs to my new win 7 64 bit machine. I play mp4 mpeg2 and mpeg1 on VDJ no error problem.
geposted Sat 16 Oct 10 @ 3:19 pm
No doesn't matter what folder they are in. Seems to be some sort of codec problem, but I can't find one for win7 that will work :( They all play fine under WinXP. Any ideas?
geposted Sun 17 Oct 10 @ 8:52 am
Tried every codec I can find so far. Still get the same in virtual DJ - "error".
Here are the details from one of the video files that won't play:
General
Complete name : E:\DiscoMusic\-=CHART=-\Song.mpg
Format : MPEG-PS
File size : 24.9 MiB
Duration : 3mn 49s
Overall bit rate : 912 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : M=1, N=12
Duration : 3mn 49s
Bit rate mode : Variable
Bit rate : 702 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.366
Stream size : 19.2 MiB (77%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 3mn 49s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 5.25 MiB (21%)
General
Format : MPEG-PS
Duration : 3mn 49s
Video
Format : MPEG Video
Duration : 3mn 49s
Bit rate : 702 Kbps
Width : 320 pixels
Height : 240 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : MPEG Audio
Duration : 3mn 49s
Bit rate : 192 Kbps
geposted Mon 20 Dec 10 @ 6:03 pm
