when I use the option to split the sound "Deck 1 Left Side and Deck 2 Right Side" my new lappy doesn't split it... I use the headphone as a back up... what is the problem!
geposted Thu 22 Jul 10 @ 3:05 pm
What sound card are you using Chuck?
geposted Thu 22 Jul 10 @ 5:44 pm
well I have a Gig-a-port and it has been fine with VDJ in my old laptop for a couple of years... I bought a new laptop and was testing it out.... so I just wanted the "split" option but that is what happened, it didn't split... does that makes sense?
geposted Fri 23 Jul 10 @ 12:34 am
You can't use Gigaport AG with Windows Vista & Windows 7. Gigaport AG is working on windows 7 by default, but 1xstereo only.
Gigaport HD is a Multidevice souncard and is working multichannel in windows 7 & Vista.
geposted Fri 23 Jul 10 @ 12:46 pm
ok that is fine,,, but the split option doesn't use the Gig-a-port just the headphone jack... it splits the signal one channel deck 1 and one channel deck 2... but it doesn't come out that way....
geposted Sat 24 Jul 10 @ 1:56 am
guess no one has an answer for me... is there a phone number I can call for help?
geposted Sat 31 Jul 10 @ 11:38 pm
Hi Chuck, I have bought a new laptop yesterday and it has windows 7 64bit and i plugged my gigaport ag in and it works fine. I set config as follows: -
Output - 3 Lines Mixer.Chan 1&2 left deck - Chan 3&4 right deck - Chan 5&6 samples/preview.
Sound card states - 6.1 Speakers (GIGAport AG)
And just for the record I used my Gigaport AG on my other 2 computers (My old laptop that has now died, and my pc which i use as back up which are both running Vista)
geposted Fri 15 Oct 10 @ 3:53 am
