Ok, I am a newbee... I just want to have the left deck play on 1/2 and the right deck on 3/4...
What do I do?
Thanks,
Vin
What do I do?
Thanks,
Vin
geposted Mon 06 Jun 05 @ 3:40 pm
I think you must go to the advanced settings of the soundcard in Virtualdj.
If you can't find this option, you must scroll down in the soundcard settings.
geposted Mon 06 Jun 05 @ 4:19 pm
I went to that portion and chose Gigaport for left and right deck but I am only getting signal on 1/2 not 3/4 ????????
geposted Mon 06 Jun 05 @ 4:40 pm
Look into the cover of the card and see which red lights are lit when both decks are playing.
You may find 5&6 live, not 3&4.
geposted Mon 06 Jun 05 @ 5:05 pm
You have to use Channels 1&2 and Channels 5&6, don't ask me why.......
Henry
Henry
geposted Mon 06 Jun 05 @ 7:28 pm
Download the newest ASIO 2.0 drivers and you will be able to use all 8 ports.
geposted Mon 06 Jun 05 @ 7:34 pm
Thanks for the help... I think the ASIO driver is the way..... I will download it today and give it a shot.
Vin
Vin
geposted Mon 06 Jun 05 @ 9:41 pm
The ASIO Driver worked PERFECT with the GIGAport.... Thanks to all!
geposted Tue 07 Jun 05 @ 1:09 pm
Ok....Problem not solved... ASIO worked great for one night and then the next day I got "ASIO Driver Error" and I can't assign the ports anymore.... Help???
geposted Tue 07 Jun 05 @ 4:18 pm
Reinstall the software. If you downloaded the correct driver you should have to plu in the soundcard twice. I had this happen once and reinstalled and fine...
geposted Tue 07 Jun 05 @ 6:09 pm
Also, remember to keep plugging the card into the same USB port. If you change ports then you have to, in most cases; reload the drivers if you change ports. As I said in most cases. Also, if you don't have the card hooked up at all and you launch VDJ then that is a common error to receive.
cstoll
cstoll
geposted Wed 08 Jun 05 @ 2:18 am
I think you guys have saved me....working good now!
Thanks,
Vin
Thanks,
Vin
geposted Wed 08 Jun 05 @ 9:32 pm
Ok... So I have gigport working on the right outs etc but I seem to get a "beep" and gigaport flashes about once every 60 seconds... Whats up with this?
Thanks,
Vin
Thanks,
Vin
geposted Fri 11 Nov 05 @ 1:02 am
You have downloaded the wrong asio 2.0 driver. i went to the esi website and don't see the link to the free asio anymore. Try this one:
http://www.esi-pro.com/download.php?division=1&type=2&pid=12
And select the one you need. See if that helps.
Maybe this is it:
http://www.download.com/USB-Audio-ASIO-Driver/3000-2120_4-10108225.html
Let me know for the link used to be right on the esi site.
Maybe this is it:
geposted Fri 11 Nov 05 @ 2:09 am
I figured it out.... Asio only gives you a 30 day trial... I purchased it and now its all set!
Thanks,
Vin
Thanks,
Vin
geposted Fri 11 Nov 05 @ 4:29 pm
There was a free one out there without the beeps. Maybe its gone now.
geposted Fri 11 Nov 05 @ 4:37 pm
Is this the driver?
USB Audio ASIO Driver 2.0.4
Requirements: Windows 98/ME/2000/XP
Publisher: Propagamma/usb-audio.de
Limitations: Beeps every 30 seconds
Date added: May 27, 2002
File size: 964.88K
License: Free to try; $55.00 to buy
File size: 964.88K
geposted Sat 12 Nov 05 @ 1:21 pm
