I have VDJ 6.08. For some reason I lost 2 functions on my DMC2 controller.
1.) Time Display does nothing. I would like it to flip though total time, elapsed time... How do I map this?
2. Deck A on DMC2 only shows the total time of the song. It does not show the time running which has elapsed like it does on the VDJ screen.
How do I map this to count down the seconds of the song? Deck B is running.
geposted Thu 22 Jul 10 @ 5:36 pm
Display_Time. This fixed both problems. You have to add the _ line or it will not work.
geposted Thu 22 Jul 10 @ 6:02 pm
If you have not made your own modifications to the mapping, simply go to CONFIG -> Mappers, choose the DMC-2 in the drop-down list and then click the reset to factory settings button at the bottom-left of the dialogue box.
Otherwise, change the mappings as follows:
TIMEDISPLAY
Press the TIME DISPLAY button of each deck to toggle it to the appropriate display mode that you want (This must be done for each deck separately.)
TIMEDISPLAY
display_time 'elapsed,total,remain'
geposted Fri 23 Jul 10 @ 12:35 pm
