Hey guys, I have a hard drive with about 100,000 or so songs on it, so it takes more than a few minutes to scan the hard drive to get it in the search database. Problem is every time I close virtual DJ and open it again, it has to scan the entire drive every time before any search results come up. This seems crazy to me. Is this how it really is supposed to be? Any answers are much appreciated thanks so much. - Alex
geposted Fri 23 Jul 10 @ 3:00 am
NTFS ?
geposted Fri 23 Jul 10 @ 5:51 am
Do you have a licensed copy of the program? That may help.
geposted Fri 23 Jul 10 @ 2:47 pm
@ DJ Ace Cap1 - he could be a trial user!! Please try and help if you can, if not don't say anything ;-)
@ akaye - this could be a permission issue within Mac OS:
CStoll - from another thread wrote :
Make sure your permissions are correct for accessing the database files ...
Go to the /Documents/ folder and Control+Click (right click) on the VirtualDJ folder
Choose the Get Info menu choice
Then in the bottom right corner of the Get Info dialog you need to click on the pad-lock and unlock it (will prompt you for you user password)
Then just above that to the left is the Permissions list. Make sure your user account has Read/Write permissions set.
Just below the Permissions box there is a button with a gear graphic on it - click that and choose the 'apply to all included' items
Once changed, close the box to Apply the changes.
Might have to do this with your external drives as well.
geposted Fri 23 Jul 10 @ 4:33 pm
