My question to anyone out there is...
I have the ion's iCue DJ controller...
It doens't come with a mic jack so I can pre-cue/pre-listen to music with...
I purchased "Griffins" iMic today to see If that would work...
I didnt see results...
Is there any way possible for me to pre-cue/pre-listen to a song on Virtual DJ?
Thanks so much!
Thanks so much!
geposted Sun 25 Jul 10 @ 12:54 am
Hello, with the iCue you can prelisten with a soundcard which supports more than two outputs. You can configure this in the sound options.
geposted Tue 27 Jul 10 @ 2:30 pm
Hey thanks alot
Do you know if the "Griffin" iMic 2 Sound Card will work?
(I am on a mac f.y.i)
Thanks!
Thanks!
geposted Tue 27 Jul 10 @ 2:55 pm
geposted Tue 27 Jul 10 @ 2:56 pm
As I said in my email yes that should be ok, you may notice slight latency with that card however as its not designed for DJ use.
geposted Wed 28 Jul 10 @ 2:59 pm
