hi all. Has any user ov VDJ in or around Brighton experience in getting laptop audio to run smoothly when using VDJ?
I have a fab new laptop but despite doing all the mods to background programmes etc its still slightly glitchy when running (sound hiccupped 5 times in a 90 minute set. At 10K its very noticable (to me anyway!!))
can anyone help?
thanx all.
xxx
can anyone help?
thanx all.
xxx
geposted Sun 25 Jul 10 @ 7:11 pm
Did you disable wifi, bluetooth, anti virus, power saving, and any other auto functions?
geposted Sun 25 Jul 10 @ 8:10 pm
here's what you tell people so they can help .....
she has a dual core 4gigs ram vista home prem 64 bit and a low end shared memory graphic card
hit control shift esc and then processes tab ......how many processes ??
in config/performances set presets to fastest
under sound setup you should be on asio and check ultra latency and 2 lines mixer
geposted Sun 25 Jul 10 @ 9:35 pm
Hi there. the laptop isn't using Vista its Windows 7 and the laptop specs are...
HP i3 dual core Operating with: Windows 7 Home Premium (64-bit)
CPU: 2.13GHz Intel Core i3-330M
RAM/Expandable to: 4GB/8GB
Hard drive size/speed: 500GB/7,200 rpm
Optical Drive: 8X DVD-Super Multi DL
Graphics/video memory: Intel GMA HD/shared
Display size/resolution: 15.6 inches/1366 x 768 Phew!!!
and not forgetting my trusty RMX.
i've turned off everything i can find including Wifi, Networking, AntiVirus, Bluetooth, Power saving, Performance over Best looking etc and even got a programme called Game Booster which turnes off every background programme that isn't being used.
i have no option to adjust Config as i'm only using the LE version ov VDJ. Not sure how to adjust Sound Config or Latency etc on Asio.
Hope that has given everyone the info they need to assist me.
Thanx all.
XXX
Thanx all.
XXX
geposted Mon 26 Jul 10 @ 7:59 am
ctrl shift esc , then processes tab , how many processes......
2 lines mixer ...
set the herc as the soundcard
asio check ultra latency ......
change system priority to background processes or vice versa
are the rmx drivers up to date ...
click config then sound setup.......
inputs none
outputs external mixer
soundcard .....select the hercules from the dropdown box
under that it says asio config check the box for ultra latency, click apply then ok
do happy dance
2 lines mixer ...
inputs none
do happy dance
geposted Mon 26 Jul 10 @ 8:47 am
THANX BABE. NOT BEING A SUPERDOOPER PRO USER I CANT DO THE QUOTES THING SO I COPIED AND PASTED YOUR MESSAGE BELOW AND FILLED IN MY ANSWERS WITH SHOUTY CAPITALS...I HOPE YOU DON'T MIND... I'M DEFINATELY NOT SHOUTING AT YOU...
ctrl shift esc , then processes tab , how many processes...... 24 PROCESSES ON THE LIST 3 OR 4 RUNNING WHEN MIXING.
2 lines mixer ... ??? DONT KNOW WHAT THIS IS OR HOW TO DO IT.
...........Do you mean SOUND PLAYBACK SET TO RMX DEFAULT.
SOUND- RECORDING- LINE 2-HERCULES- DEFAULT DEVICE.
WITH SOUND SCHEME SET TO NO SOUNDS.
COMMUNICATIONS SET TO DO NOTHING.
asio check ultra latency ...... DONT KNOW HOW TO DO THIS WITH THE LE VERSION OV VDJ AS ALL THT IS OFFERED UNDER THE CONFIG TAB IS A TRIAL VERSION OV THE PRO SOFTWARE.
change system priority to background processes or vice versa .........NOT SURE WHAT OR HOW TO DO THIS
are the rmx drivers up to date ... ........YES (PHEW, GOT ONE!!)
click config then sound setup....... DO YOU MEAN CONFIG IN VDJ (SEE ABOVE ANSWER) OR SYSTEM CONFIG ON WINDOWS 7? AS THIS ACCESES THE FOLLOWING TABS ---START UP SELECTION, BOOT, SERVICES, STARTUP AND TOOLS.
inputs none .............???
outputs external mixer ............???
soundcard .....select the hercules from the dropdown box ........ ???
under that it says asio config check the box for ultra latency, click apply then ok ...........???
do happy dance .............NOT DOING A HAPPY DANCE YET I'M AFRAID... HOLD THAT HAPPY FIDDLE!!!
HELP!
I THOUGHT YOU HAD IT THERE BUT I DONT SEEM TO BE ABLE TO DO ANY OV THESE THINGS!!! :o( SAD FACE.
XXX
HELP!
XXX
geposted Fri 30 Jul 10 @ 4:24 pm
is there a tab in config called sound set up?
geposted Sat 31 Jul 10 @ 9:37 am
hi babe. Nop, under the Config Tab the only thing thats there is an offer to either buy the pro version or download a trial verson...
i think its a bit off that Config is a Pro userthing only... For us "non Pro users" Setting up the system is important too!
Thats my little moan over with.
feel better now.
XXX
feel better now.
XXX
geposted Sat 31 Jul 10 @ 4:31 pm
Love is Everywhere ! at VDJ!
geposted Sat 31 Jul 10 @ 10:08 pm
