hey guys i have a problem with my headphones...
i use vdj with vestax vci300 and the headphones motinor level is too low...
the volume level on my headphone is not good...
can anyone help me??
geposted Mon 26 Jul 10 @ 6:53 am
Which Version of VDJ do you use?
geposted Mon 26 Jul 10 @ 8:02 am
i use 6.0.8 pro my friend
geposted Mon 26 Jul 10 @ 8:17 am
did you register it yet?
I've had that problem before, and some of the skins on here give a separate headphone volume.
BUT! the way I fixed my problem was I went into "open volume control" in Windows, clicked on options, then properties.
Once the dropdown window popped up, i clicked on it, then chose the headphone option, then i was able to turn the sound up. Make sure you change the default back to your main soundcard when done
geposted Mon 26 Jul 10 @ 2:06 pm
Greetings,
I use a Samson Headphone Amp when I play somewhere with high sound volume. The headphone output of my laptop is not always powerful enough.
http://www.google.com/products/catalog?rlz=1T4GGIH_enUS233US233&q=samson+headphone+amp&um=1&ie=UTF-8&cid=11128274215884162801&ei=8PRNTKn4NcH78AbJn5n3Cw&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CEwQ8wIwAg#
I come out from my 3.5mm headphone jack and plug into the Amp's 1/4" input. It makes the headphones sound full and clear.
It's an extra piece to hook up, but if the surronding sound is high it's the only way to CUE properly. Good luck.
Regards,
Jim
Regards,
Jim
geposted Mon 26 Jul 10 @ 3:55 pm
